Problem importing from Solidworks 2014.
rballerini
Hi all,when amount of a cylinder, from Solidworks 2014 inside Creo 3.0, the central axis of the cylinder is no longer displayed.
chip
Riccardo,
I sorry I used improper term "correct behaviour". I wanted to use term "intended behaviour".
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS104772 reports that datum geometry (datum planes/curves/csys/points) is not imported from SolidWorks parts.
Martin Hanak
Martin Hanák
Riccardo,
I guess that disappearance of an axis is correct behaviour. Can you upload some model for testing (How to upload Creo (or other) files) ?
Martin Hanak
Martin Hanák
Hello, correct behavior? But if I have to pair it with a servomotor as you do?
It 'a problem if I do not have the axis ...
thanks
Riccardo,
Martin Hanak
Martin Hanák
