Problem with drawings (scale)
ptc-1180442
2-Explorer
Good Morning guys, I have had a problem with drawings in Pro/E wf 4.0 M070. When I try of change the drawing scale Pro/E is closed. How can I fix that?
anyone knows how to fix this?. thank you.
Sounds like some kind of corruption. I would try installing a newer version, or at least reinstalling the M070 version. If it always happens on that same action I don't see how that could be a hardware issue. Maybe it could have to do with your drawing template. Does it do it if you have a drawing with no template?
