Hi All
I use Creo 2
When I have to create reference planes in drawing, I have to create them in the 3D model, and choose them to be demonstrated in the drawing. But the problem is that this plane(s) apear then in every single view I have created. Then I will have to remove the redundant ones manually.
Is there a better way?
Yes. They appear in all the views. You can control the display of the planes using the layers for that specific views and hide as you want.
Thank you very much
Could you please tell me how this could be done?
