Problems with RSD 9.0 and Cabling
MichaelTurner
I am trying to use Cabling and RSD 8.0 with Pro Engineer WF 4, but when I go to add wiring between ports, the icon ( X ) is not there, and all i have is a yellow ( - ) instead, not allowing me to add any wiring.
I have looked at and followed the online tutorials and I am still unable to do the function.
Looking for assistance, as it is probably something silly, I have overlooked.....
Just a note, when I am running the training programme, I am having to convert some of the functionality as Iam using RSD 9.0, not sure if this is the root cause of my problem or not though
Just an update for the post, the software is converting the application from 7.1 to 9.1 when I try to open, new sheets and start a schematic.
The problem exists in Cabling also and has the same funtionality in converting everything to 9.1.
I really need assistance on this as it is driving me nuts
check the following :
1) you are using the same diagram type for the fibers and the connector/component (ports parent)
2) if the port is already connected to fibers/other port - check the value of 'Max connections per port' , if you reach this value, you won't be able to connect nothing to the port
