Query Select not working if WF5
TedOtto
3-Newcomer
Recently got upgraded to Wildfire 5.0. I'm having troubles with the Query Select working. I'm trying to take a distance measurement and on a cast part I have, I can RMB and query thru items to pick for my distance measurement, I can hold the RMB and get the Pick From List option to show up. Works fine, just like in WF4...I jump over to merged model/machined part and try to do the same thing and no matter what I can't get anything to highlight using the RMB...if I hold the RMB I get the To/From/Direction Collector options to show up and that's it. I can LMB and pick whatever is on top, but the query/RMB is not working. The filter is set to All in both parts, I changed them to see if it'd help, but nothing works. Has anybody else seen this happen?
Thanks!
Ted
0 REPLIES 0
