I have just run an interesting hyperelastic model, it took 3 days and did not complete. (I can't share the model).
Over the 3 days I periodically monitored the study and watched the RAM get gradually used up (including virtual disk)
eventually it ate the complete 48Gb actual and lots of virtual and completed with a fatal error at step 150 of 201 on pass 2.
Fortunately the info I required happens at about step 140.
Any thoughts?
Creo2.0 M100
13585 bricks and wedges
Hello Charles,
We have recently received a report that a rather simple model failed LDA contact analysis with hyperelastic materials and development is currently looking into it.
However, in that other case, the analysis failed already after half an hour, so this is very likely something else.
If possible, you should open a case with PTC Technical Support.
I would think, 48 GB should be enough to compute 13585 entities, even if the material contributes to some extra steps during computation.
If you want to track the cause yourself, it is normally best to simplify the model and retry.
If analysis is successful (and significantly faster, not just barely making it), add about half of the details again and try again.
If analysis still fails / needs too long, simplify it more.
Within 3 or 4 iterations you should have a good sense of what is keeping the analysis from completion.
Gunter
Hi Gunter,
if I open the case I will be asked for the model and I cannot release the information; hence I put the question here.. So this is difficult.
The model geometry is quite simple already. No opportunity for simplification.
There are several contact regions some of which are 'self contact' which simulate initially assumes cannot be valid presumably because the surfaces are too far apart. Even so, all contacts work sensibly.
All measures seem well behaved and values of forces have reasonable correlation with experimental results (a pleasant surprise)
Free body forces sum to zero.
So everything otherwise seems good otherwise
Charles
Hi Charles,
if the geometry is really that simple, can you create a new model which is similar, which you can send?
It is very difficult to diagnose without having the model in front and being able to look at the features/geometry and modify it.
Gunter
Morning Gunter,
I sent you a PM.
Charles
