REVISION MANAGER
mekins
REVISION MANAGER
Hi ,
Is there any option in Cre-o to save an assembly into desired folder without using save as option.
Similar to Revision Manager in Solid Edge Software.
5 REPLIES 5
MartinHanak
(To:mekins)
in case that you created new assembly Creo will suggest you to save it into current working directory. You can change target directory.
Martin Hanák
mekins
(To:MartinHanak)
Dear Martin ,
If I have created many parts , in  which some of the parts are not used while creating Assembly.
Then how can I save that Assembly to separate folder without using save as option.
Regards
Raghu
MartinHanak
(To:mekins)
unfortunatelly I do not understand what you need. Please provide more detailed explanation.
Martin Hanák
mekins
(To:MartinHanak)
Dear Martin ,
Once check the attached video .
Regards
Raghu
MartinHanak
(To:mekins)
I am sorry I do not have time to study REVISION MANAGER functionality.
If you want some advice, please describe your situation when working in Creo.
1.] what are your source data
2.] what do you want to get
Martin Hanák
