Take a bolted structure with fasteners preloaded and then subjected to many loadcases.
Contact interfaces making the problem non-linear. Using SPA. No changes to geometry and mesh re-used.
The first part of the calculation for each loadcase is identical.
Is there a way of re-using the solution to pass1?
This would better than halve the time. Studies I have just completed are 4 hours elapsed each.
Charles
Unfortunately, no; you'll have to re-run the preload phase for each different load case you want to look at.
Hi Steven,
I thought that too. My SPA studies reach 6/7th order with the majority of the time (75% or there abouts) on Pass1 where the edge orders are all 3. Wouldn't increasing all edges to 7th order would make it much slower? I shall try it later and surprise myself. Besides, I can't anticipate all areas where the edges need to be a higher order for any particular load case.
We used to have a 'restart' function for MPA but not to select different loads before restarting; only changing plotting grids, max p-level, output tab checks and some others I never used.
We lost the restart function for MPA sometime ago. It's not even a mecbatch option that I've found.
I know SPA doesn't write intermediate results to disk like MPA.
Steven,
No, this model cannot be shared.
Any trivial contact model will do to illustrate; fasteners are optional.
Thanks for your confirmation Shaun.
