Real-time update in extrude tool
mdahlke
8-Gravel
Has anyone else had any problems with the real-time update not working properly? When I'm creating an extrude feature, if I drag the handle for the extrude direction into the part, it doesn't create a cut; it allows me to change the length of the protrusion but won't change to a cut when it is drug into the existing part. This is frustrating because it seems to work on other employees computers but not mine.
Bari
(To:mdahlke)
Hello Mike,
Please check if you have the following config.pro setting:
auto_add_remove YES
Hope it works.
Bari
(To:mdahlke)
Hello Mike,
auto_add_remove YES
Hope it works.
TomD.inPDX
(To:Bari)
I'm not sure that is the purpose of this option since the default is "no". If you are looking for Autoswitching, then yes, the option should resolve the problem.
I was having trouble with this as well... and it turned out that solid extrudes would not remove material from surface bodies, but when I switched to "thin" feature, it would let me remove material.
mdahlke
8-Gravel
(To:Bari)
Toggling auto_add_remove fixed the issue. Thanks Antonio!
