The enhancement to Creo 8: Recursive References, is unstable on parts with large numbers of features (1000+). A video showing recursive references: https://youtu.be/WiXGPC6WfsU?t=53 By clicking "edit references" on a feature, Creo will auto-populate the next dialog box for a list of recursive references. If your part happened to have a lot of features this can take an extremely long time, about 20min for a 1200 feature part. Thus without using the recursive references, it has basically disabled the use of edit references. This is a bug; the list should only be populated when the recursive references button is pressed.
I have done some testing with this; if the feature you are editing references does not reference a quilt, there is no delay since the recursive references only slows down when there is a reference to a quilt. Does anyone know a workaround that would still let me use edit references?
Sidenote: I have a Tenth gen Intel Xeon 8core processor and 64gb of ram so I doubt the slowdown is related to that.
did you report the problem to PTC Support?
