Folks
My references dimensions are not showing in parenthesis after applying the config.pro command. Is there something wrong or else i need to do? i login-off with no result
parenthesize_ref_dim yes
I agree with Jose's post. Moreover, a datum frame is 3 mutually perpendicular datum planes, in the spirit of a four legged chair has 3 legs that locate it to the floor. The forth can be measured to but it is not controlling.
Ross H. LIberty
