Regen Models on Drawings
JamieHarless
Does anyone know if it is possible to regen all the models shown a drawing. We are having to set each model active then regen, some of our drawings have 50 to 100 models and this is very time consuming. I would like to know if any one has come up w/ a way to hit one button and regen all the models one after the other - Thanks in advance. Jamie
6 REPLIES 6
Jamie, I think prior to WF2.0, the drawing would regenerate ALL the models on it. Since WF2.0, I have not found a way to get all the models to regenerate at the same time. I have been having to set the current model, then regenerate each one. It would be nice if it was a config option you could set to do ALL or CURRENT. Dennis
Jamie, If the models are part of an assembly, then select Properties, Drawing Models, and Set Model. Once you set the model to the assembly, you should have the option to regen automatic, which will regen them all. Hope this helps, Tim
The models we are having the most problems with are sheet metal flat states. They are part of an assembly most of the time - but they dont change on the drawing when I regen the assy. I have to set each one current then regen. This is really a pain and takes up way to much time. Thanks, Jamie
I have noticed the same issue with flats and this is my work around. Set the top-level assembly as active model and regen. Save and Close the drawing, Erase Not Displayed, then re-open the drawing. All the flat states should regen to the updated values from the assembly. Rodney
These particular drawings are of flat states from various different assy's. Because the assy's are so large we dont add them to the drawing only the flat states are used. I hve noticed that when you make a change in the assy and it changes the geometry if the flate state is in session it doesn't update automatically, does anyone know why?
