Zero value for tolerances disappears on drawing
NickKaehler
7-Bedrock
Hello, I'm new to Pro-E,I'm using Wildfire 4.0. My problem is that whenever I create a dimension with a tolerance with a +0 value or -0 value the 0 does not appear with the rest of the dimension. For example 1.75+.000/-.002 only shows up at 1.75-.002 How can I get the zero values to show up on the drawing? Thanks.[/img]
I actually just figured this one out on my own. If anyone else ever has this problem open your drawing. Right click to display the drawing properties (Make sure no drawing entities are highlighted). In the menu manager click on Drawing Options. In the new windown scroll down to "blank_zero_tolerance" change this setting to "No". Click Apply, close the window and repaint your drawinh. The tolerances will no have the zero value displayed.
