Registering Windchill 11 with Creo parametric 2.0
cloni
11-Garnet
Recently after the windchill upgrade to 11.0, server registered in creo server management is not going online. Anyone know how to fix this problem?
3 REPLIES 3
TomU
(To:cloni)
What build of Creo 2.0 are you running?  Windchill 11 requires at Creo 2.0 M190 at a minimum.
TomU
(To:cloni)
You should also recreate your local cache after an upgrade.
MartinHanak
(To:cloni)
did you check whether you Creo 2.0 version is compatible with Windchill 11 ?
What Creo 2.0 version do you use ? Starting from M210, it is necessary to install Creo Agent manually to enable proper communication with Windchill.
MH
Martin Hanák
