Relation in repeat regions
Dom_BOUCHARDY
I have a message error in a repeat region with relation.
I have 2 assembly types:
- ASM 1
- ASM 2
In the ASM 1 I have the AC1_LEN_SE parameter, which is a tube length parameter
In the ASM2 I have the AC1_LEN_XX parameter, it is also a tube length parameter)
We need to know the total tube length by subassembly reference, whatever the assembly typology.
My repetition table is used in the drawings of asm1 and asm2.
I have the desired result, but I have the following message which I do not understand.
"There are errors regenerating repeat region relations."
Can you help me understand this message and how to resolve it?
Below you will find the table.
Greetings
               ELSE
               LENGTH=" "
TOTAL_LENGTH=QTY*LENGTH
In the case that length equals a space its going to generate an error because you can't multiply a space times a number.
5 REPLIES 5
I need Creo data (models and drawing) to investigate your problem. The table itself is not enough.
Martin Hanák
Can i send it by email for preserve confidentiality?
               ELSE
               LENGTH=" "
MartinHanak
(To:Chris3)
@Chris3 wrote:
               ELSE
               LENGTH=" "
@Dom_BOUCHARDY ,
if @Chris3 guessed the cause of the problem, then there is no need to send data.
Martin Hanák
Hi @Chris3
Thanks a lot, it works 🙂
