Remove axis system in creo illustrate
ptc-5494127
Hello everyone, I have just yet begun to use creo illustrate and for the project I'm working on, I need to export my figures to jpeg files.
I find embarassing while doing this to still have the axis system rendered. How can I remove it in creo illustrator, so only my assembly will be drawn without this axis system ?
On a side note, I find also stupid that the zoom of the part (or the assembly) in the figure in creo illustrate influences how the jpeg file is drawn. Only the size of the image when exporting should influence this.
Hope to be clear and thanks in advance for your help !
1 REPLY 1
To remove CSYS from window, do this:
File > Options
then select Global > Model
clear the check box for Display view gnomon
Apply > OK
Martin Hanak
Martin Hanák
