I have a part that I have made with the Merge function. I need to keep the original sketches in the merged part (for cut references). Cutting the merged part reveals the merged sketch lines. Now when I then make a Drawing of this part the merged sketches are visible in the drawing. How can I remove them? I've tried to uncheck the View-> Display Settings-> Model display -> Shade-> With datum curves box but they are still there. Changing the color so they are not visible is not an option as they are still visible in a pdf.
Is there a solution to this?
Have you tried hiding the "curves" layer from the layers tree in your drawing?
Try hiding the merge feature in your new part (select the merge feature in the model tree, right click Hide) - this doesn`t hide any solid geometry just datums and surfaces. Save Staus in the Layer tree to keep the changes.
