Rendering / Enhanced Realism / Image Output
tgiauque
Gurus & Wizards,
Today I am attempting to export some presentation-quality images from Pro/E. The images are of an exploded view of an assembly, and there are explode lines illustrating where the components are supposed to go. So how do I get some *good* images out of Pro/E? I can use the Render module, but I can't get it to show the explode lines. So, I can turn on "Enhanced Realism," which isn't as nice as Render but, well, it's good enough, but there's a shadow directly beneath the view that I can't seem to get rid of.
So can I do one or more of the following? I'd like to
1) Include the offset lines in my rendering, or
2) Move or hide the shadows in the "enhanced realism" image.
Any ideas? I'm using Wildfire 5, M030.
Tim
Tim Giauque
Project Engineer II
FN Manufacturing, LLC
Phone (803) 736-0522 x383
Fax (803) 865-3543
Tim,
To turn off shadows try going to View>Display Settings>Model
Display-select SHADE tab go to Real-Time Rendering box where you can
"click" off shadows and reflections then hit Ok
Dave Martin
Sr. Industrial Designer
Toro Co.
gkbeer
(To:tgiauque)
Turn off the display of the room to remove the shadow on the floor.
--Glenn
On Wed, May 12, 2010 at 6:45 AM, David Martin (Lyndale) <
-> wrote:
> Tim,
> To turn off shadows try going to View>Display Settings>Model Display-select
> SHADE tab go to Real-Time Rendering box where you can “click” off shadows
> Dave Martin
> Toro Co.
