Reorient (View) button missing from ribbons
cprice
Has anyone noticed the Reorient button is missing from Creo Parametric 2.0 (m090)?
If you use the search area, the search tells you it is not located on the ribbon menu.
Making the selection from the search area will open the orientation dialog box.
I haven't had the need for it in a while (since I switched to Creo 2 Parametric), but I just ran into this.
Am I missing something and there is a new way to reorient (and easily create) saved views
Charlie Price
kkrahmer
7-Bedrock
(To:cprice)
It is under the Named Views Pull down menu in the floating view toolbar in the top of the modeling area.
3 REPLIES 3
kkrahmer
7-Bedrock
(To:cprice)
It's also under the same on the "View" tab in the orientation section.
Thanks - I got fooled by the search in help saying it wasn't in the ribbon.
C.P.
