Repeat Region Parameters Question
Phillip1
Greetings,
Is there a source that lists, or better yet, explains the syntax parameters available for repeat regions?
7 REPLIES 7
Phillip,
try PTC Help Center. It is available on separate DVD in Creo 2.0.
Martin Hanak
Martin Hanák
Phillip1‌, did you ever find a list the function syntax  for repeat regions?  Every once in a while I look for this and don't think that I ever found anything comprehensive.  When I search the help for Creo it doesn't come up.
"When you reward an activity, you get more of it!"
Phillip1
(To:LawrenceS)
Lawrence,
I didn't find an actual list. I was able to find what I needed and resolve the problem I had.
Bummer but glad to hear you made do...can you share some tips on how you searched for information on a particular function.  For example, I have tried the following and other variants, but cannot get anything: "Repeat Region Relations Exists".
Thanks!
StephenW
(To:LawrenceS)
Stephen Williams‌, thanks for although that is different than what I am looking for, it is still very useful info!
I am looking more for the syntax and uses of operators.
I started a document with documentation that I had started a while back.  I chose document so everyone can contribute and modify it.  TomUminn‌ posted some very helpful links to within the PTC Creo online help, which I didn't find when I searched.  So anyone looking for this info, navigate to this doc and check out what he wrote in the comments at the bottom.
Wiki type Doc: Creo/ProE Drawing Repeat Region/BOM Syntax...Please contribute! 🙂
