Greetings,
Is there a source that lists, or better yet, explains the syntax parameters available for repeat regions?
Phillip,
try PTC Help Center. It is available on separate DVD in Creo 2.0.
Martin Hanak
Phillip1, did you ever find a list the function syntax for repeat regions? Every once in a while I look for this and don't think that I ever found anything comprehensive. When I search the help for Creo it doesn't come up.
Lawrence,
I didn't find an actual list. I was able to find what I needed and resolve the problem I had.
Bummer but glad to hear you made do...can you share some tips on how you searched for information on a particular function. For example, I have tried the following and other variants, but cannot get anything: "Repeat Region Relations Exists".
Thanks!
Not sure this is what you are talking about.
Stephen Williams, thanks for although that is different than what I am looking for, it is still very useful info!
I am looking more for the syntax and uses of operators.
I started a document with documentation that I had started a while back. I chose document so everyone can contribute and modify it. TomUminn posted some very helpful links to within the PTC Creo online help, which I didn't find when I searched. So anyone looking for this info, navigate to this doc and check out what he wrote in the comments at the bottom.
Wiki type Doc: Creo/ProE Drawing Repeat Region/BOM Syntax...Please contribute! 🙂
