Repeat Region Relation and Cagec issue
  • July 19, 2021
  • 1218 views
I have the following relation in my relations for a BOM that simply removes the specified cage code:
IF exists("asm_mbr_cagecode")
	IF asm_mbr_cagecode == "12345"
	my_cagecode = " "
	ELSE
	my_cagecode = asm_mbr_cagecode
	ENDIF
ENDIF
 Which has worked as intended, EXCEPT I am now noticing that there are a few parts in my BOM that are pulling the incorrect cage code from another unrelated part. Without the relation, I don't have this issue. Not sure where this issues may be coming from.
Best answer by TomU
Makes sense.  "my_cagecode" is a repeat region level parameter and it's value is static unless something changes it.  When "asm_mbr_cagecode" doesn't exist, there is nothing to change "my_cagecode" to some other value.  You need to either pre-initialize "my_cagecode" or add an extra ELSE statement.
my_cagecode = " "
	 my_cagecode = " "
 ELSE
 ENDIF
ELSE
 my_cagecode = " "
ENDIF
TomU23-Emerald IVAnswer
my_cagecode = " "
	 my_cagecode = " "
 ELSE
 ENDIF
ELSE
 my_cagecode = " "
ENDIF
kspabs1-VisitorAuthor
Awesome, this fixed it exactly and makes sense why I was seeing this behavior. Thank you!
