Repeat Region
zzbuggs
Repeat Region
Hi All,
I have a repeat region (Parts List) with 8 columns and it works great. Now I wish to remove the parameter (&NEXT_ASSY) from one of the columns and make that column a manual entry cell.....Is this possible
Thanks, and Happy Thanksgiving
-TT
1 REPLY 1
mlocascio
(To:zzbuggs)
TeeTee,
You "may" have to re-develop that table so that certain areas are excluded.
I am assuming that you made a "simple" repeat region originally. In order to
use that column manually it cannot be included in the repeat region. So your
table will have to be defined so that it includes the areas that you want to
populate in a repeat region and another portion will need to be defined as a
manual area. You "should" be able to redefine your repeat region to
accomplish this.
Mike L.
