Repeat Regions / Filters
DANIEL_MD
6-Contributor
I'm trying to exclude parts from the BOM. I was instructed to open Repeat Regions, then select Filters, then click on the BOM and 2 options would appear, Remove: By Rule or Buy Item. But it will not even let me click on the BOM. Not sure why its not functioning properly.
kdirth
(To:DANIEL_MD)
Check out this post:
Solved: Table Filtering - PTC Community
Chris3
(To:DANIEL_MD)
Are you sure that your table is a repeat region?
It should work like this:
https://youtu.be/xAge8cmyAj8?t=465
DANIEL_MD
6-Contributor
(To:Chris3)
When I select By Item it gives me this....:you may not perform this action due to symbol asm.mbr.cparam
kdirth
(To:DANIEL_MD)
Hello @DANIEL_MD
It looks like you have some responses from our community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
