Repeat Regions
nhanratty
Repeat Regions
All
Just a question on default 'sorting' behaviour of repeat regions for BOM tables.
I have two repeat regions in a drawing neither of which have any 'sort' regions defined.
If I change the order in which the parts have been assembled in the model tree one of my repeat regions updates to reflect that order change which is what I want...but the second table does not.
Like I said neither table has a sort region defined and the second table does not have any fixed records/indices or regions so does anybody know why the parts in the second table are not following the order change?
Thanks for any suggestions.
Neal
Scott
Spot on that’s the answer…thank you.
The table that wasn’t working had the attributes setting No Duplicates.
The table that is working has the setting No Duplicates/Level
Neal Hanratty
Engineering Systems and Standards Manager
Terex Materials Processing Group
T +44 (0)28 8241 8769
F +44 (0)28 8225 2740
M +44 (0)75 3495 2739
E neal.hanratty@terex.com<">mailto:neal.hanratty@terex.com>
