Dear ProE users,
Here is my situation.....
When a singlepart is used in a top level assembly and a weld stud or weld nut is added to the part a newsub-assembly is required. A new assembly is created with the part and weld stud or weld nut. Then the new assembly has to be replaced with the single part at the top level which is actually the same part but with an added component. This may be in many places and takes a while to replace all the constraints to eachassembly it is used. We are considering taking all of our single parts and adding them to an assembly even though there may not be an additional component added to it at that time. This would allow us to add or subtract parts without having to swap out a part for an assembly or the other way around because they would always be at the assembly level.
Does this make sense?
Is there another way to approach this?
any suggestions on this subject would be appriciated.
Kevin
