Resend: WF5; Unexpected Axis visibility on ProE drawing
BrentDrysdale
Hi Folks,
I sent this a few minutes ago but it may have been rejected as my work email
address has changed. I have updated my user profile so it should come
through now. My apologies if it comes through twice.
Original message.
We are looking to move from WF4 to WF5 as there are many things about it we
like. However after a bunch of work there is one thing that is causing me
to stop the process.
When I make a ProE drawing and bring in a model with various axes, either
directly created or made as part of an extruded arc/cylinder, these axes
show on the drawing even though the feature that creates them is layered off
in the drawing. (this seems to be true in M010, M020 and M030).
At first I thought it was some new thing I was doing in WF5 but further
checking shows that it is still true if I make a new blank drawing in WF5
using a part made in WF4. What is driving me crazy is that in the drawing
the layer that this feature is on is hidden. I can select the axis using
the Annotate Tab and "Show" it then it will appear in the Drawing Tree and
then I can "erase" it to make it not show on the drawing but this is a very
long winded process and would be worse for complex parts with multiple
axes. I also thought that maybe this was just for axes made in extruded
arc/cylinder features but it is also the same for Axes made as features
directly. Only the axes are seen, not the axis tag that go with them.
Our VAR sees the same behaviour and have a call in to PTC.
Our default drawing detail file has *draw_layer_overrides_model no* which is
a hold over from WF4. I have tried to set it to *YES* which I understand is
the default setting in WF5 but without any visible change.
Do other people running WF5 see this behaviour and if so id it something
that bothers you?
As a separate item I notice that the Layer ISOLATE command has vanished from
WF5 drawing though it is still there in the model. This is also somewhat
distressing to me as the power of ISOLATE to control layers is very good. I
do not think this is related to the above problem as none of the layers in
the part or drawing were isolated, only hidden; and our VAR was able to
replicate the issue with a brand new part and drawing and none of our
settings.
Regards, Brent Drysdale
Senior Mechanical Designer
Tait Radio Communications
New Zealand
DDI +64 3 358 1093
www.taitradio.com
0 REPLIES 0
