Restriction - Read access only
Amirtharaj_K
Hi Guys, I want to share the model to the vendor but vendor can view only they can’t measure manually and modify it.
Is there any option for this?
Aj
2 REPLIES 2
Are you both on the same version of Creo Parametric?
Does the vendor have Creo View instead of Parametric?
Apologize for the delay in the reposne.
@Dale_Rosema Yes, both are the same version and they have Creo View.
Aj
