I have a file made with SketchUp and converted to.stl.
I would like to open it in Creo 3.0 but I can't.
The file is not even seen when you choose Open *.stl.
It seems to me that in the past there were no complications?
Is there any information missing in the Config.pro?
Sincerely.
Denis
Aqua cuve 2000L.stl is not visible in Creo because of spaces in filename. Rename it to Aqua.stl :).
Thank you both for your answers.
Yes, indeed the spaces in the title, I got screwed!
Sincerely.
Denis
