I have been using AHK and I have the script to reverse the mouse behavior (as found in How to reverse the mouse wheel zoom)
This is my script:
#IfWinActive, ahk_class Dialog
WheelDown::WheelUp
WheelUp::WheelDown
RETURN
Well, I got a new PC and when I installed AHK and ran my script, I get an error.
I can change the #MaxHotkeysPerInterval command, but as soon as it gets to "1" above whatever limit I set, I get the error. Problem being that nothing else is tied to this script command and all I do it move the mouse slightly... at the 70 interval, I get the error by just moving the mouse one notch.
I am not too familiar with AHK and how it behaves with Creo, but it was working fine in one machine and not in this one. Any ideas?
So going through the AHK board. I have come across the sad fact that the problem is, in fact, a setting on this new computer that my employer gave me. I tested the script on my coworkers machines (some are like my old model and some like my new one) and this seems to be an isolated incident. I will post later here if I ever figure out what the problem is. As it stands right now, reversing my mouse doesn't seem to be an option for me.
If using Creo 3.0 there is a config option:
use_inverted_mousewheel_zoom
No need for AHK.
