Revision Control - Latest working / latest released / exact
AnthonyC
hey everyone,
i am having issues that i hope someone can help with.
when checking an older iteration or revision of an assembly, the items underneath have updated to the latest version, despite the copy not having revision n+1 at the time or a completely different part.
i understand this might be because i didn't have the workspace cleared but in essence, how would i open/ check an older iteration without needing to clear the workspace/ new workspace each time?
is there also no way to force an exact revision for everything in the structure tree?
1 REPLY 1
StephenW
(To:AnthonyC)
You have to add the assembly and all it's components in an "as stored" or "baseline" configuration. It's possible, but not easily within a existing workspace with parts/assemblies already present. Its relatively easy to update an out-of-date item in your workspace but is it usually more time consuming to make existing parts "out of date". Almost always faster to just make a new workspace, add the assembly "as stored" with components.
