Revit dump (follow-up)
brianlynn
Got a call from a AutoDesk VAR, and I asked if there was something you
could export out of Pro/E to import cleanly in to Revit. He called me back
later and said that Pro/E is suppose to be able to do a Save A Copy to 3D
DWG format which should open right up in Revit. I ordered WF 5 and
installed it on a laptop here and upgraded the license server. Now that I
have an assembly open I cannot find a way to export to 3D DWG does anyone
know if this is something extra that you have to purchase for Pro/E WF5 or
is it simply I do not know what I am doing?
Thanks for any information you might have on this.
Brian S. Lynn
Technical Coordinator, Product Engineering
0 REPLIES 0
