"Chris Benner" wrote:
I've come to expect the weird and unexpected from Pro E.
"Fitzgerald Chris" wrote:
Hi CM, I have seen similar to what you have. For me it happens when I am in a drawing with multiple models. I will change a dimension, it will green, I hit regen and it does not change. I have found it does not regen because the model that I changed the dimension on is not the "active" model in the drawing. Regards-
