Rotate Auxiliary view
cfetters
I'm using WF5. When creating views in a drawing can you rotate an Auxiliary view? I attached an image to clarify intent.
Not AFAIK. The aux view is oriented to the plane or edge used to create
the 'hinge' line for the view. If you need to rotate the aux view or
aesthetic reasons you must change the aux view to general, and then use
conventional methods to orientate the view (if possible)
Christopher Gosnell
TRIGON INC.
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
PH: 724.941.5540
FX: 724.941.8322
www.fpdinc.com
