How do I use the flexible modeling move command to rotate surfaces? I can move them linearly, but how do I rotate them 90 degrees? I am using CREO 10.
Can you provide more information on exactly what you are trying to do. The geometry being rotated makes a difference. (e.g. surface/solid surface)
Basic rotation move for any geometry:
Thanks.
