Rotating surfaces
JB_9812715
3-Newcomer
Rotating surfaces
How do I use the flexible modeling move command to rotate surfaces?  I can move them linearly, but how do I rotate them 90 degrees?  I am using CREO 10.
kdirth
(To:JB_9812715)
Can you provide more information on exactly what you are trying to do.  The geometry being rotated makes a difference. (e.g. surface/solid surface)
Basic rotation move for any geometry:
  • Add coordinate system to define rotation axis.
  • Select Move
  • In steps tab, select handle placement origin and select coordinate system
  • Drag spin handle for free move.
  • Select Orientation and select a plane to create a dimensioned rotation before dragging.
kdirth
(To:JB_9812715)
  • Select Move
JB_9812715
3-Newcomer
(To:kdirth)
Thanks.
