I can't figure out how to follow cable in Creo 2.0. It used to be so simple in WF4!!!
Can anyone shed some light? Options are Cable to follow: <pick wire>
From: <what does the system expect?> To: <What does the system expect?>
I pick a location from and a location to but yet it does not work.
I can successfully route it manually picking each location point, but it will just not follow it!!!
Any videos out there??
In Creo the From and to should always be defined first (e.g. by logical data or by manually selecting) - only then different methods to route are available.
You can add locations or use other means, like selecting to follow network / other cables.
