How to set default normal dimension to default basic dimensions in sketcher,this would be helpful for me to save time
sdara
2-Explorer
How to set default normal dimension to default basic dimensions in sketcher.jpg
Can you guys help me on this
Thanks in advance
5 REPLIES 5
MartinHanak
(To:sdara)
I think that you cannot set sketcher dimensions (sd#) in Sketcher mode as Basic dimension. This can be set in Part mode for model dimensions (d#).
MH
Martin Hanák
sdara
2-Explorer
(To:MartinHanak)
Thanks for the replay
Can we able to change in background sketcher file,may be xml file or backgorund file
to get Basic dimension in sketcher
MartinHanak
(To:sdara)
unfortunatelly it is not possible. Ask PTC Support if you want to be sure.
MH
Martin Hanák
Hi Sateesh,
Unfortunately, it is not possible for customers to modify any hard-coded information that is part of the functionality.  You would need to submit a Product Idea to see if the behavior/functionality you are looking for, can be added into a future release.
Amit
BenLoosli
(To:sdara)
Why do you need sketcher dimensions in basic? Basic dimensions are only 'valid' when shown on a drawing with datum planes for the GD&T functions.
Sketcher dimensions should be simple and easy to modify. Put the precision into the dimensions on the drawing.
If you are trying to convey the model dimensions as being basic when you do a Y14.41 exported model, then that needs to be stated in your product idea.
