I have been speaking to a number of interested parties for more than a year now, and I have gained the firm impression that when we change the whole company to Windows 7, our Pro/Intralink 3.4M062 and Pro/Engineer Wildfire 4 M220 setup will not run.
We did some tests here and could not get the Intralink setup program to run at all.
Now, looking on this forum, I seem to be reading that it is possible to make it work.
What is the position?
Have you any experience of running this software combination?
Is there a penalty for running it?
Did you have to jump through any hoops (Pro/Workaround) to make it work?
Is it worth the risk, or should I be pushing to migrate to PDMLink & Creo 2 - and swallow the tens of thousands of pounds cost for what seems to me to be no quantifiable benefit?
Is there even a definitive answer?
PTC Support website is no help, as far as my searches show.
John
See Lawrence Srutkowski post
http://portal.ptcuser.org/p/fo/st/topic=3&post=92214#p92214
In summary, set javaw.exe into Vista compatibility mode (not Vista SP1, or Vista SP2). I have successfully launched the INTRALINK 3.4 M062 client on Win 7 x64.
