Running simulation with higher cores
AM_10402502
3-Newcomer
How to run simulation using higher number of cores?
2 REPLIES 2
I fear that you are not in the correct community. Here you are in the community "Creo Elements Direct" that is a software different from Creo Parametric. You should move your post to the community "Creo Parametric" to have a better chance to get an answer.
http://kotom.eng.free.fr
Thankyou! I'll post in the parametrics community
