Sketch plane not turning parallel to the screen
ptc-5321926
Hi!
i have a simple but very annoying problem:Whenever i choose a plane to do a sketch the view doesn't set automatically any more to be parallel to the screen, and i have to do it manually...
Does anyone know why is it like that?
Thanks in advance
Best regards
Hector
Open the Options dialog and search for "Sketch" (without the quotes) You are looking for an option that orients the sketch view. If I knew it offhand, I'd mention it. There's also an icon that's tough to describe that re-orients the sketch plane to be parallel to the screen while you are in sketcher, for when you spin the model and want to get back.
Thanks!! It was that easy and worked!!
