configuration file
johnnyD
configuration file
I'm trying to export a STEP file from Autodesk Alias to pro/e w5.0 using these directions http://www.autodesk.com/techpubs/aliasstudio/2010/index.html?url=WS73099cc142f48755-b872b1811d6c581626-4c2e.htm,topicNumber=d0e134839.
It tells me to go to utilities>options and then to paste the data into my configuration file. I don't know where to find the utilities or where to paste the new data so any help would be great.
Does anyone else have experience using alias and pro/e together, I'm new to both and could use some input. Thanks.
Hi John
If you are searching for the configuration options in PRO-E then you have to go to Tools &go to Options
Regards
K.Mahanta
once I've opened the options where do I add the new configuration data?
Hi
The above image is a sample screenshot of configuration options
In the left side box (option) write the option and in the right side box choose/write the value
then press add and apply
add one by one all the options
Regards
K.Mahanta
