SUMMARY: Instance Accelerator Files
TerryMcFall
ORIGINAL POST:
Has anyone out there found a benefit from using family table Instance Accelerator files (they create .xpr and .xas files in your working directory)?
If so, what size of family tables are you using and how have you managed them in Intralink?
SUMMARY:
Not many replied and several repeated their decision to turn this function off using the following config.pro setting:
save_instance_accelerator none
One user provided some helpful context to their use:
"They do speed up retrieval times but they also take up a lot of disk space. I don't make huge family tables in terms on number of instances (20 max, usually less). but some of them are quite complex. The other advantage is if you want to use the Acrobat 3D PDF functionality. It is imperative that you have accelerator files if you want to create 3D PDF without Pro/E running.
For data I'm working on daily I save them. For old products that only get revised infrequently I delete them.
We don't use Intralink."
Another user mentioned problems updating them:
"I've found drawbacks. I turned mine off after I found instances were not updating when I changed master parts."
-Ter
Terrence (Terry) McFall
CAD Systems Administrator
Varian Medical Systems
911 Hansen Way
Palo Alto, CA 94304
650-424-6039 desk
650-799-0179 cell
0 REPLIES 0
