Now maybe this was setup intentionally by PTC...
When you save a view within a model that contains, lets say, 5 parts.
You adjust the model with a certain orientation, distance zoomed in, and particular location, say one of those parts as the center of the view.
Now you remove one of those parts from the model and you pick the view you saved earlier. Now you find, due to the part being removed or even a part added, has caused the saved view to have a different location center and a different zoom level.
Does anyone know how to keep the views from doing that as the model changes?
You could even test this by having an empty assembly, save a view of the top assembly coordinate system as the center of the view and then add a part. You'll find the coordinate system is no longer at the center of view.
Currently I'm using Wildfire 4.0 Build M130
Unfortuately the problem I'm having is model only, no drawings involved.
Basically I'm setting up views in the model so when you use the drop down "Named View List" in the modelwindow I want it to show the same zoom level and locationeverytime the view is selected. But unfortunately if I change, remove, or add a part to the assembly the saved views in the model shift in either location and/or zoom level. If there was a way to set an origin at the model level that would be great.
I'm not sure how I'm creating the views to be dependent on the parts themselves. Basically I drag the model and rotate it into the orientation I want then go up to the Reorient view button to save the view I currently have on the screen. I hardly ever use a reference as in regards to the Reference 1 and Reference 2 options on the screen when creating that view. I just name the view and press save. Then when I delete something from the model and activate that view it's as if thecenter of the view moved.
