Scaling model
mino12345
3-Newcomer
Scaling model
Hello I need a advice about scaling model. I have a assembly and I want to scale it and then assemble it to other assembly scaled it is possible?
Thanks.
5 REPLIES 5
You can scale your model but it is a permanent operation.
Can you expand on the use-case?
 I tried to scale it but it doesn´t work.
How did you try to scale the model?
I tried it with scale and the with changing measurements
Hi @mino12345
 in my opinion you should scale each part separetly. For example with some macro.
BOTTOM UP ASSEMBLY:
1. open aseembly
2. choose desired part from assembly model tree
3. start recording macro
4. right mouse button open model
5. choose scale model
6. input desired scale
7. regenerate model
8. close part
9. choose other model and repeat method from point 2
BOTTOM DOWN ASSEMBLY (drived with skeleton)
1. scale sceleton
2. related parts schould be scaled
Hope it can helps
Regards
@mbonka
