Scaling part & subparts
jsalazar
When using the Part & Subpart Scale command in Creo Elements/Direct 18.1 Drafting, all the subparts below the main top part should reset their scale factor to the main top part scale factor when the top part scale is change?
When doing so, not all my subparts are resetting to the main top part scale factor. What may cause this to happen?
2 REPLIES 2
Hi Jacob, have you any subparts set as 'Symbol' parts?
You can check this in the Part Browser - in there you should find a column header 'Symbol'.  If the part has a star in this column, then it is a 'Symbol' part.
Barry,
Look into the browser and the items don't have the "Symbol" icon next to them.
