I'm in the process of switching to Creo4 and was wondering how to make the insert row the same width as the other rows. I tried copying over my screw_dialog.res from creo3, but it had no effect.
this is fixed in Creo 5.0.
Find attached the new screw_dialog.res file.
Hi Oliver,
For some reason this file causes creo to crash when the screw dialogue is supposed to open. Do you have one that is compatible with Creo4 M030?
Thanks alot Oliver. Is it possible to expand the thread series name like you were able to for CREO3?
