Scroll wheel behaviour in WF4
ptc-50033
Hi All,
We've recently upgraded from WF3 to WF4 and whilst I'm loving drafting
open quilts, there is one thing that's bugging me:
In WF3 you could drag features up & down the model tree and whilst
dragging you could use the mouse scroll wheel to zip up & down the tree
faster. It's great for large models with many features. It also worked
well when dragging the 'Insert Mode Arrow' up & down the model tree.
However, in WF4 you can't seem to be able to do this. You can use the
scroll wheel, but not with anything selected.
Does anyone else have the same problem? Has anyone found a solution to
it?
I've tried the PTC helpdesk, but after difficulty in explaining the
problem and spending most of the call duration explaining HOW to
actually drag features up & down the model tree, I lost all faith that
they would come up with a solution!! Hence, my plea to the forum.
Ian
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender immediately and delete this e-mail from your system. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of Ricardo (save for reports and other documentation formally approved and signed for release to the intended recipient). Only Directors are authorised to enter into legally binding obligations on behalf of Ricardo. Ricardo may monitor outgoing and incoming e-mails and other telecommunications systems.
By replying to this e-mail you give consent to such monitoring. The recipient should check e-mail and any attachments for the presence of viruses. Ricardo accepts no liability for any damage caused by any virus transmitted by this e-mail. "Ricardo" means Ricardo plc and its subsidiary companies.
Ricardo plc is a public limited company registered in England with registered number 00222915.
The registered office of Ricardo plc is Shoreham Technical Centre, Shoreham-by Sea, West Sussex, BN43 5FG.
Please see feedback from PTC below. I will (for what it's worth) be
submitting an Enhancement Request to try and get the old functionality
back.
Ian
Solution Details - TAN 140182
Solution
140182
Type
TAN
Created Date
12-Feb-2008
Last Updated
12-Feb-2008
Title
Inability to Scroll in the Model Tree Window by Holding the Left Mouse
Button (-LMB)- and Using the Scroll Wheel
Details
Description
For models with a large feature list (scroll bar visible) it has been
possible to navigate through the feature list by holding LMB on Insert
indicator (red arrow) or any other feature in model tree and scrolling
with the middle scroll button. This worked in versions before
Pro/ENGINEER Wildfire 4. Starting with Pro/ENGINEER Wildfire4 this
behaviour is no longer supported.
Resolution
The pre-Pro/ENGINEER Wildfire4 behaviour was in contradiction to the
specifications and has been corrected with Pro/ENGINEER Wildfire 4.
The scrolling with the mouse wheel should _not_ be supported during a
drag & drop operation.
The correct process to navigate through the model tree is by moving the
mouse near to the upper or lower border of the Model-Tree.
To increase the speed for scrolling you should move the mouse slightly
in the horizontal direction, once scrolling has started.
Ian Kimberley
Senior Design Engineer
Tel: +44 (0) 1926 319401
