The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Andrew,
As of Wildfire 3.0 you can create PDF files via the File->Save_a_Copy command and select PDF as the output file type. If you use this method (for drawings)you have the option to use either stroked text or text via True Type fonts (see the second tab, "Content",in the dialog). If you select True Type fonts, you will automatically get searchable text. If you select stroked text you may also select to have that text searchable. I hope this helps.
Asa
