Hello All,
I am getting an error on regenerating a revolve feature of a quadrilateral cross-section saying:
"Section regeneration failed. Ambiguous sketch."
Please let me know, what is Ambiguous sketch?
Thanks in advance,
Manoj
Try using the section validation tools to make sure you have created a valid sketch:
These tools are Shade Closed Loops, Highlight Open Ends, Overlapping Geometry and Feature Requirements. Details for each check are available in the Help Center.
Thanks Scott!
actually these sections are based on 4 points which are generated by a program with no human interactons....and after regenerating it works well without making any changes...so I am not quite sure why this is hapenning and the solution for it?
Thanks in advance,
Manoj
